Gas: 87 or 89 with Ethanol?
Posted similar question in HD forum.
What do you all think about running 89 octane fuel with ethanol in the Burb? It's actually cheaper here in Nebraska than the straight 87 octane...
Unless you have the Flexible Fuel option for your vehicle Don't Do It!! High amounts of Ethanol can mess up the inside of your engine. (Rust I believe). I am not sure, but you might want to check your owners manual. It will give a maximum allowable ethanol content. Again, the flexible fuel option (which allows the use of E85 gas) is another story. But if you just have a standard issue engine I wouldn't use it.
All 1/2 ton Burbs built from '02 to current have the 5.3l Flexible fuel option. So, you can run up to 85% EtOH in your wifes 'Burb and be fine.
    ottogriffin
    ottogriffin
  • Who's Online   4 Members, 0 Anonymous, 665 Guests (See full list)
