AutoWood Steering Wheels
Do the LS Suburbans that do NOT have steering wheel controls have pre-wiring for the volume control/Cruise/Message Center in the steering wheel? I want to do the Group purchase but the link is not working so I can't ask questions directly. Need help :cheers:
No, you have to change out the airbag coil to one that has the wires for the controls.
Thanks for the info :thumbs: If I were to do as you mentioned above is it a labor intensive job?
Not really. You have to pull the steering wheel off and then the coil is held by a snap ring. You have to run the wires down the column harness and such. Not sure about wiring in the newer ones, but on the 02-down it was just 4 wires.
if your planning on putting steering wheel controls on your 04 truck then more than likely there is more to it then just replacing the wheel and coil kit. I say "more than likely" because some trucks have the instrument cluster already programed for the full dic even though they don't have the steering wheel control option, but most trucks are not programmed with the full dic only limited dic (milage, hr's, and trip). You would have to upgrade your whole guage cluster with on SS or escalade, or one that already had the steering wheel controls or get your dealer to get the codes to reprogram the cluster. Then you would have to get your dealer to get another code to reprogram your radio (it's another name for it but I can't think of it right now, data bus or something) to be able to control your radio from your steering wheel controls. You can look on the radio and sound forum and there is a topic that would explain this more clearly.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
