suburban trailer wiring harness
sledrace
I have a 2003 suburban 1500 2wd factory wiring harness, plug and hitch. Tekonsha prodigy brake controller. I have working charging system, signal, running, brake lights and working electric brakes. Problem: no voltage at the plug on the truck for charging the trailer batteries. I think I have isolated the correct fuse under the hood but 3 dealers and the GM help line were unable to tell me exactly which fuse it is. The trailer wiring matches the truck wiring. I was told by one dealer that GM had trouble with corrosion on the in the trailer plug. I took the the plug apart and the wires are molded into the plug. No way to check them without cutting the wire. I tried sticking a pin in the 12 volt wire to check continuity between the wire and and the pin inside the plug but the wire and coating are so hard I kept breaking the pin. How do I find the correct fuse under the hood. My 88 suburban was a cinch. The 12 volt wire was not buried in a wiring harness and ran separatley with a bayonette fuse. Any ideas
Does this help?
Thank you for researching this but I found my answer.Sorry about that I hit the wrong button. I found the answer yesterday after hours of searching. Some guy that had an 03 and an airstream had the same problem. Seems GM changed everything around in 03 but never told anyone. Now it seems if they did this with my truck why didn't they do it on everyone? Then the dealers would have found out about when every new suburban ordered would have been brought in for diagnosis of the problem I had. Why the 3 dealers or the GM tech line didn't know about it I don't know. The vehicle has a factory towing package which includes hitch and wiring. This didn't even appear in the manual. There is no fuse or breaker. You have to buy one and put it in. Under the hood in the fuse box on the top left there is a red plastic plug in a terminal labeled STUD 1 or blank labeled with a capital B+. On the right there is a terminal labeled STUD 2 (auxiliary power/trlr brakes). Auxiliary power is what screwed me up. The owners manual says don't use a fuse in STUD 1 but it also doesn't say "but use a breaker. Now the packaging that the breaker came in was labeled fuse when in fact it's a breaker. How many people would know whether they bought the right part. I added a 40 amp breaker and guess what I have power at that wire. I was so close to cutting the plug since the wires were molded in. That's like not putting a fuse in the radio that comes with the truck.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
