Teacher is a Vikings Fan
OnBelay
In a school just outside Minneapolis, a first grade teacher explained to her class that she is a Vikings Fan. She asked her students to raise their hands if they are Vikings fans too. Not really knowing what a Vikings fan is, but wanting to be liked by their teacher, their hands all fly into the air. However, there is one exception. A little boy named Timmy has not gone along with the crowd. The teacher asks him why he has decided to be different.
"Because I am not a Vikings fan." says Timmy.
"Then," asks the teacher, "what are you?"
Timmy says "I am a proud Green Bay Packer fan!"
The teacher is a little perturbed now, her face slightly red. She asks Timmy why he is a Packers fan.
"Well, my Mom and Dad are Packer fans so I'm a Packers fan, too," Timmy responds.
The teacher is now angry. "That's no reason," she says loudly. "What if your Mom was a moron, and your dad was an idiot?
Timmy smiled and said, "Then I'd be a Viking Fan."
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 1 Anonymous, 746 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
