BUILDING ONE INCREDIBLE SYSTEM
blacksmoke
Im new to this site and would like to start building a sterio system using some componants i now own if possible.I have an 05 chevy crew cab lt with the center console no sunroof with bose,which im sure will all be replaced,but my hopes are to use the speaker openings in all 4 doors.Id like to build a very high quality system,i guess this system quality will be dictated by the componants i now own.I feel the quality of my componants are a 7 on a 1-10 scale,please correct me if this is far off because they were built in 1998.I have four amps,one pre amp. a source selector and two electronic x-overs as follows; (TWO)SONY MOBLE ES XM-2100G 2 CHANNEL BRIDGABLE AMPS. 1-OHM DRIVE, MONO BLOCK CONSTRUCTION 360Wx1@[email protected]
100Wx2@[email protected]%THD (TWO)SONY MOBLE ES XM-260G 2 CHANNEL BRIDGABLE AMPS.1-OHM DRIVE,240Wx1@[email protected] 60Wx2@[email protected] (TWO)MB QUART QM300.72 MUSICOMP ELECTRONIC X-OVERS (ONE)SONY AXC30 SOURCE SELECTOR AND (ONE)SONY MOBLE ES XDP-210EQ 21 BAND DIGITAL PRE AMP. I would like to build a sub box to inclose two 10 inch subs i have an ipod and would like to include 1 in dash dvd/cd/xm/possable nav.If any one could fill in some high end possibillities of speakers head units anything to end up with a very clean musical system that can hit hard but crisp.I have always had 8 inch subs and would really love to move up to the next level.I have 2 batteries and will soon have 2 alts. any recommendations on alts?I also have a diesel if it matters.I know there are so many manufacturers of speakers and head units but i think alpine haed units(high high) end is possible and for speakers, i just want as close to the best without getting stupid expensive.I know ill need in the 12 to15 range of speakers,remember my amps.,give them a rate # then match acordingly Keep in mind the 05 dash/center console has a lower area, im thinking of putting an a-2 a new edge with aditude with color moniter with ecm chip, navigation and reverse camera option.There are other options for amp.config. dif. ohm/THD combos so if 4 ohm is not optimal please set that straight.I am by no means a high fi pro. but i can build any box and wire anything with the right instructions,this may be far too much for most but i know there are some here whom will accept this as a challenge and once approved i will bring it to life like many of you motivated truck guys and gals.Please change what i have if you must but i feel good about the quallity of the sound these amps have to offer. THANK ALL OF YOU FOR ANY AND ALL HELP IN ADVANCE----any questions please pm me any time.... :thumbs:
