Switching to Synthetic
With 88k just be sure to keep your eye on it, some people will have some leaks once the synthetic cleans out the deposits from the dino oil.
on my 94 TA, I switched to Mobil 1 with 80K on the clock. I did initially have an oil leak, but it eventually sealed itself and quit.
I've switched over to synthetics on vehicles with as many as 120,000 miles and had no problems. The synthetic sure did clean out the engine from the years of dino use. :banghead:
DEWFPO
I switched over to Synthetic with 88,000 on my truck and didn't have a problem, you shouldn't have one either. I am going to be switching back to Standard Valvoline 5W30 or 10W30 As it stands I change my oil every 5000 regardless, I don't think there is any advantage to having synthetics since many vehicles out there make it to 200,000+ miles on standard oil alone and I'll be rid of my truck by then.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 353 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
