What do you see?
04-silver
try to look into the picture and train yours eyes in the center.
(Although I don't recommend this, going cross eyed slightly seems to work well)
:crackup:
John
Edit:its hard for some but it will work
Edit:let me rephrase this"Can you see it?" 3D
What I see isn't appropriate for this site.
But hey...I see that when I stare at the foam on hot cocoa, so I bet that it's not what I'm supposed to see in that pic.
If you look into the pic you will see a 3D image of something, although I could see the image, I just couldn't make out what the image was supposed to be.
I have a bunch of these but this didn't seem to go over as well as I thought it might, so I'll save you all from wasting 3 minutes of your life :chill:
:nopity:
John
