GMC Sierra Steering rattle and Oil Gauge Issues
jfrostjr
I have a 2000 GMC Sierra Z71 with a 5.3L V8. I have two issues that I am looking at some help on.
I experience a rattling/vibration through the steering wheel (mostly at low speeds). I have it going on for a while now, but now it is really becoming quite an annoyance. I read something about a lubrication kit and also about an intermediate steering shaft replacement. Do you have any info or service tech document ID's I could have my dealership refer to? I have heard the lubrication kit will fix, although typically temporarily, and that the newly designed shafts will correct permanently?
The second issue deals with my oil pressure meter on my instrument cluster. The oil pressure reading needle shakes all over the place at various times in the truck. It will do it in park with the engine idiling. It will do it while in gear and driving. It will do it at idle while in gear with the brakes on. The only time it seems to not shake is under moderate to heavy acceleration. I have had the dealership look into and they replaced the sending unit,but that does not seem to have cleared up the issue. Do you have any ideas? Once again, any services tech docs or light you could shed would be greatly appreciated! Thanks for your help in advance!
Jack
If your dealer doesn't know about this issue, they're from Mars and you should probably try to find a dealer that has earthlings working there. :crackup:
I'm not familiar with this specific issue but it sounds like the gauge itself. No TSB's that I'm aware of.
How hard would you rate the difficulty of replacing the intermediate steering shaft to correct the issue (per TSB 00-02-35-003? I know it is hard to gauge, but a rough estimate would be great, or if anybody has any experience with it that they would share it would be great to hear about also. Thanks!
Jack
Our lube guy changes them. Does that give you a little idea how easy it is? I will admit the lube guy is probably a little more experienced than most lube guys, but still...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
