Need diff oil capacity on '02 SD w/4WS
Front Drive Axles (8.25")
Capacity 1.66 L (1.75 qts.)
Front Drive Axle (9.25")
Capacity 1.73 L (1.83 qts.)
Rear Drive Axle (8.6")
Capacity 2.28 L (2.41 qts.)
Rear Drive Axle (9.5")
Capacity 2.6L (2.75 qts.)
Rear Drive Axle (9.75")
Capacity 2.84 L (3.00 qts.)
Rear Drive Axle (10.5")
Capacity 2.6 L (2.75 qts.)
Rear Drive Axle (11.5")
Capacity 3.62 L (3.83 qts.)
Lubricant Level Check
1. Raise the vehicle. Refer to Vehicle Lifting.
2. Make sure the vehicle is level.
3. Inspect the front axle for leaks. Repair as necessary.
4. Remove the front differential carrier shield (if equipped).
5. Clean the area around the front axle fill plug.
6. Remove the front axle fill plug (1).
7. Inspect the oil level.
o The oil level should be between 0 - 13 mm (0 - 0.5 inch) below the fill plug opening.
8. If the level is low, add oil until the level is even with the bottom edge of the fill plug opening. Use the proper fluid. Notice: Refer to Fastener Notice in Service Precautions.
9. Install the fill plug.
o Tighten the plug to 33 Nm (24 ft. lbs.) .
10. Install the front differential carrier shield (if equipped).
11. Lower the vehicle.
    250.3k
    pimafe6931
    pimafe6931
  • Who's Online   2 Members, 0 Anonymous, 948 Guests (See full list)
