97 fuel filter replacement problems
Well, I tired to change the fuel filter on my daughters new 97 Chevy and the aft nut is rounded out. Thanks to whomever didn't use as flare nut wrench! I think I'm going to have to replace the whole fuel line...any input from the crowd?
Hmmmm, I don't recall if that's a standard flare or if it's type with an o-ring. Probably the latter.
If it's a standard flare, you could cut it off and reflare it. It needs to be a double flare and there may not be a way to make up for the amount of line you'll lose by cutting.
Try a torch.  :chevy:
Before you follow ^^ that advice, remember the disclaimer.
Please remember that we are not responsible for any messages posted.Federal law, specifically the Communications Decency Act, 47 U.S.C.A §230, states that websites are immune from any liability for statements authored by others. We do not vouch for or warrant the accuracy, completeness or usefulness of any message, and are not responsible for the contents of any message.
Best to try a smaller propane type torch. :crazy:
Please, do NOT do this.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,032 Guests (See full list)
