Cake and eat it too!!!!
Black02Silverado
It's small, it's fast, it's frugal - and it's coming to a VW dealer near you
If you live in the UK you can get one soon. Too bad we cant buy really light cars in the USA :fume:
Sure you can, it's called a "motorcycle". :fume:
Seriously though, too bad that thing still isn't as fast as my truck*.
*Downhill...In a tornado...With a sail...And a rocket
but what can your truck do 0-60 in? :confused:
  • 3 weeks later...
Anyone know the import costs to purchase one in the UK and have it shipped over??? Just a thought. I have a British boss, I will ask him.
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 716 Guests (See full list)
