Joe Gibbs front bumper mock up
Just finished taking the HD bumper off the truck and took some picks of a used Joe Gibbs front bumper positioned for evaluation purposes, looks pretty good to me, but I must ask, whadda ya'll think? and, should I green-light this conversion?
It's going to take a little bit of work to fit, however, its not going to be that big of a deal. The biggest problem is the fact that everything hanging off the front end on an HD sits 2" lower than a 1500series truck because of the taller frame, no worries though, I'll just have to massage the stock bumper mounts a bit :fume::confused:
anyway
I think it looks good! Smooths out the lines up front really well...kinda reminds me of the one-piece front bumper look coming out on the 07 Tahoe.
If you can get the mounts to line up properly...I say go for it!
:fume:
If you decide to to do it...make sure you put some pics up when you're done! :confused:
Update:
Finished the brackets, I'm using stacks of washers for now, need to get some aluminum spacers machined up at the correct measurements. Bracket relocation is rock solid, I can shake the entire truck quite well from one bracket alone, front to back strength seems good as well. enjoy:)
Heres a pick with the actual bumper bolted up to the modified brackets:
and a couple of pics with the JG bumper resting on it:
I'm on the flip side of the coin and say that I like the stock bumper better than the JG. But that's me. You do what you want.  :fume:
thanks for your input :fume:
Final mock-up pics, heat exchanger and intercooler pump relocated, bumper firmly in place, everything clearanced and fitting well :judge:
Now that I look at it, I kinda like the chrome grill, and I think the JG bumper looks more proportionate with the "power dome" hood over the 03-05 non HD hood.........hmm........what should I do, any recommendations are welcome at this point :confused:
Go for a painted or SS grille, paint the mirrors, go with Escalade door handles and paint the tailgate handle. Leave the body side moulding, since that keeps some of the road noise out plus it ties the bright wheels in with the bright strip in the moulding and the chrome bumper.
Just my $0.02
SS :fume:
Just my $0.02
SS :fume:
sounds like you've done this before, got any pics of your setup?
Just my $0.02
SS :fume:
I can't post any pics on this site since I don't have a website to host my pics.
I have posted some pics on Performance Trucks website.
I've got pix at QuadrasteerClub.com, but you have to be a member to see the posted pictures.
I'll figure out a way to get them on this site!
I like the JG bumper, I have a 2004 2500HD CC D/A how much trouble would it be for me to raise my stock bumper and get a 2006 painted bumper cap. Been wanting to do this since I bought my truck.
If anyone has do this before your info would be appreciated.
    250.3k
    user087
    user087
  • Who's Online   1 Member, 2 Anonymous, 811 Guests (See full list)
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
