Stuck Spark Plug
There's a spark plug I can't get off. It's on there TIGHT. The other ones came out fine. I was wondering if I could spray some WD40 down there and see if that'll loosen it up? :cheers:
Cylinder #1. Nope, WD40 didn't do it. I sprayed a lot in there heh. SEALED. :cheers: I'm afraid of ripping the top off the spark plug. That would be a bad thing.
I would try some PB Blaster, that stuff is the BEST I've been able to find for losening stuck stuff. I would let it set for awhile then use a breaker bar, making sure the socket is on the plug squarely. Remember, you can always try and tighten it a bit to break it free too.
I second the PB Blaster recommendation! That stuff is just plain awesome.
