WILL NOT HOLD IDLE UNTIL IT WARMS UP
2000 GMC TRUCK SIERRA 1500 4WD
8 Cylinders 294 V 4.8L SFI
Truck seems to run fine, but check engine light is on. My mechanic checked for codes, but said there were no codes and turned the light off. I have had no problems cranking, until the last few mornings have been below 45 or maybe 40 degrees. The engine cranks, but goes dead. I give it some peddle, and it runs, but goes dead immediately when I let off the peddle. I can hold the peddle for a minute or so, and it warms up enough to run normal, and the check engine light goes off. It comes back on within a few miles. This morning was warmer, about 60 degrees, and it started and idled perfectly. I am going to check the codes again, but just wanted to see anyone has run into this.
Thanks!
I would also check your cap, rotator, wires and plugs (if ur truck has them). I know on my 98 when it starts doing that it is a harbenger that i need to replace my cap and rotator
    250.3k
    Griffin Donovan
    Griffin Donovan
  • Who's Online   3 Members, 0 Anonymous, 665 Guests (See full list)
