THE PERFECT HUSBAND
Scyry
Several men are in the locker room of a golf club. A cell phone on a bench
rings and a man engages the hands free speaker-function and begins to talk.
Everyone else in the room stops to listen.
MAN: "Hello."
WOMAN: "Honey, it's me. Are you at the club?"
MAN: "Yes."
WOMAN: "I am at the mall now and found this beautiful leather coat.
It's only $1,000. Is it OK if I buy it for Christmas? "
MAN: "Sure, ..go ahead if you like it that much."
WOMAN: "I also stopped by the Porshe dealership and saw the new 2005
models. I saw one I really, really, really liked."
MAN: "How much?"
WOMAN: "$90,000"
MAN: "OK, but for that price I want it with all the options."
WOMAN: "Wonderful, wonderful. I love you very, very much!!! "
MAN: "Bye! I love you, too."
The man hangs up. The other men in the locker room are staring at him
in astonishment, mouths agape.....
He smiles and asks: "Anyone know who this phone belongs to?"
