93 BLAZER SURGING
VICSTRANSAM
I have a 93 Blazer with 5.7 TBI. It has a surge after warmup at 2000 and below rpm. I discovered if I unplug the EGR the surge goes away. I get no codes. What is the primary cause? O2? Coolant temp sensor for the ECM?
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 193 Guests (See full list)
