Warranty Almost up - Making list for dealer
My warranty is almost up on my '04 Sierra, and I am making a list of the things I need to have replaced or checked.
Here is what I have so far.
1. Steering shaft - Rattle/loose feel
2. AC Controls - passenger side will not return to cool air unless the vehicle is killed and restarted.
3. Passenger side trim has bubbles in the chrome.
4. Rear seatbelt. (recall)
5. Power Steering pump whine.
6. Rear brake squeak at low speed.
Any other suggestions or things I have missed???
Thanks for any input.
-Jon
-Jon
I know mine has this issue, I always wondered why dealing with the fuel cap was such a problem:
Fuel Cap Tether Too Short to Hook on Fuel Door While Fueling Vehicle (Install Fuel Filler Housing and Cap) #05-06-04-043A - (Aug 2, 2005)
2004-2005 Cadillac Escalade Models
2004-2005 Chevrolet Silverado, Suburban, Tahoe Models
2004-2005 GMC Sierra, Yukon Models
This bulletin is being revised to correct the fuel filler cap P/N.
P/N 15225006 is released for 2006 and 2007 model year vehicles only. The correct fuel cap for the 2004 and 2005 model year is P/N 15225005. Dealers who currently have P/N 15225006 on order (possibly back-ordered) for this concern should cancel their order and re-order P/N 15225005.
Please discard Corporate Bulletin Number 05-06-04-043 (Section 06 -- Engine/Propulsion System).
Built Prior to the following VIN Breakpoints:
Plant
Plant Code
VIN Breakpoint
Arlington, TX
VIN Code R
5R230316
Flint, MI
VIN Code F
5F922638
Fort Wayne, IN
VIN Code Z
4Z279906
Janesville, WI
VIN Code J (GMC)
VIN Code J (Chevy)
5J226244
5J226273
Oshawa, ON
VIN Code 1
51302641
Pontiac, MI
VIN Code E
5E274724
Silao, MX
VIN Code G
5G234433
Toluca, MX
VIN Code M
5M116355
Condition
Some customers may comment that the fuel cap tether is too short to hook on the fuel door while fueling the vehicle.
Cause
The existing fuel cap tether is too short.
The existing fuel filler housing elongated hole is too small to accommodate the new fuel cap tether.
Correction
Important: Clean the fuel filler cap and surrounding areas prior to removing the fuel filler housing in order to avoid possible contamination.
Remove the fuel fill cap.
Remove the fuel tank filler housing to fuel tank fill pipe screws.
Remove the fuel tank filler housing to body TORX® screws (1) and retainer (2).
Important: It is NOT necessary to raise the vehicle in order to remove and/or install the fuel filler housing.
Remove the fuel filler housing from under the vehicle.
Install the new fuel filler housing, P/N 15289921, from under the vehicle.
Install the fuel tank filler housing to fuel tank fill pipe screws.
Tighten
Tighten the screws to 2.3 N·m (20 lb in).
Install the fuel tank filler housing to body TORX® screws and retainer.
Tighten
Important: The new fuel cap, P/N 15225005 , tether strap installs in the elongated hole in the fuel filler housing. DO NOT install the new fuel cap tether in the round hole in the fuel filler housing.
Install the new fuel cap, P/N 15225005 , tether strap in the elongated hole in the fuel filler housing.
Install the fuel fill cap on the filler pipe and tighten until the cap clicks.
Parts Information
Part Number
Description
Qty
15225005
Cap, Fuel Filler
Housing, Fuel Filler
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
B9753*
0.2 hr
*This labor operation is for bulletin use only.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
i never knew that the cap tether was suppost to hang on that clip , the cap has a slot on the cap that clips right on the little clip thingy . it hangs there like it was designed that way . my 04 yukon is long enough but my 04 silverado isnt , but i thought that maybe they just changed it for some reason .
PISTON SLAP
TRANSMISSION CLUNK 2-3 UPSHIFT
Both are known problems to GM and I for sure would have it on the work order so when it craters out later there is a paper trail for you to go on.
    ballencd
    ballencd
  • Who's Online   6 Members, 1 Anonymous, 667 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
