code p0446 and speedo calibration question
roy67ss
Hi GM Tech, I'm back with a couple of questions.
1. I bought the kit to recalibrate the 88-91 truck speedometers. I plugged the connector in and touched the red(+) and black(-) wires to the battery as the instructions say. It did not seem like anything happened which is verified by no change in the speedometer reading. Is there supposed to be some action like a spark or pop or smoke or something to suggest that something was fried? I tried it on both the moony and the tach cluster with no difference.
2. My 99 4x4 Silverado NBS has recently lit up the ses light and the code I got was P0446. My Mitchell repair shows a TSB related to plugged venting of the evap canister as a possible for trucks used like I do - lots of mud and gravel roads. I suspect that this will likely be what is causing the fault. Is this a servicable venting system or will I likely be needing to get the revised assembly as mentioned in the TSB 02-06-04-037 dated June 2002 ?
PS. I have also noticed that it does not take fuel as fast as it used to and often need to hand feed it very slowly because it keeps kicking the nossle off even at the first notch.
Thanks, Roy
1. I don't recall there being a noticeable snap or pop when the fuses blew but it has been quite a few years. They're just tiny little fuses. Definitely no smoke. Are you sure there's no change? It's not like you're going to have a 30 mph difference between calibrations.
2. I'd put in the revised vent valve. LOTS of problems with those and yeah, if it can't vent it would probably contribute to the gas pump kicking off due to pressure build up in the tank. In severe cases, such as trucks used in farming applications, they suggest running a hose from the vent valve all the way to the air cleaner housing so it can only get filtered air in the valve. You might not have to go that far.
Thank for the advise again,
1. I expected some sort of reaction from what I read here. There should be a significant change because the cluster came out of a 2wd with 3.42 gears and 15" tires. The truck its going into has 4.10 gears and 265 16" tires. The speedo reads about 45mph when going about 60mph, which is still the same as before I did the burn thing.
The harness I got for connecting to the cluster has 7 red wires connected together and 1 black. Does that sound right? It makes sense from what I see on the printed circuit board.
2. Do you know offhand what the part # is for the vent assembly I should replace?
Thanks, Roy
Honestly, I don't remember. I used to have one of those around here somewhere, but I haven't seen it in a few years. Sounds right but I couldn't guarantee it. Did you put in the new clip with the proper pins broken off?
As for the vent valve... I'm sorry, I don't know part numbers. The bulletin you mentioned should have a part # in it I believe.
Yes, I broke off the ones suggested on the sheet.
I'll do some more experimenting on the weekend.
If the burn worked and I didn't put the clip in, would the speedo work at all? If it wouldn't then, I would know that the burn had worked.
The buletin info I was reading just described the symtoms and cure, but no part #'s. Probably a shortened version for the Mitchell program.
Thanks, Roy
Here's the full TSB you mentioned, including the part number...
DTC P0446 (Restricted/Blocked EVAP Vent Path) Set, Service Engine Soon (SES) Lamp Illuminated (Replace Hose/Evaporative Emission (EVAP) Canister Vent Asm) #02-06-04-037A - (Feb 2, 2005)
1999-2003 Chevrolet Silverado Models
1999-2003 GMC Sierra Models
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 02-06-04-037 (Section 06 -- Engine/Propulsion System).
Condition
Some customers whose vehicles are operated in dusty type environments, such as farming or mining off-road type applications, may comment about the illumination of the instrument panel SES light, with a DTC of P0446 (Restricted/Blocked EVAP Vent Path) being set.
Cause
Dirt and dust intrusion into the EVAP canister vent hose assembly, resulting in restricted air flow, may cause this condition.
Correction
After following the Service Manual diagnostic P0446 and determining that the EVAP canister vent valve is the cause of the SES light, replace the existing EVAP canister vent hose assembly with a new assembly, P/N 15086429. This new assembly has an enhanced filtering capability and a filter element that can be easily removed and cleaned. To ensure correct installation, follow the procedure below.
Raise the vehicle. Suitably support the vehicle.
Disconnect the EVAP canister vent valve electrical connector.
Disconnect the vent valve pipe at the EVAP canister.
Remove and retain the EVAP canister vent valve bracket mounting bolt.
Disengage, from the underbody, the two vent valve pipe clips securing the pipe to the underbody.
Remove and discard the complete EVAP canister vent hose assembly.
Position and secure the new assembly to the underbody using the existing hole and mounting bolt.
Tighten
Tighten the bracket mounting bolt to 12 N·m (106 lb in).
Install the two vent valve pipe clips into the existing underbody holes.
Connect the vent valve pipe to the EVAP canister.
Connect the EVAP canister vent valve electrical connector.
Lower the vehicle.
When properly installed, the new EVAP canister vent hose assembly will be positioned outboard of the original installation location. This new location provides clearance for accessing the filter element for cleaning purposes. To access the filter element, disengage the filter cover to valve locking finger by gently lifting the finger upward while simultaneously rotating the filter body clockwise. After approximately 45 degrees of rotation, the filter can be disengaged from the valve by gently pulling outward. The filter cover can then be removed and the filter element and body can be washed with soap and water. Prior to reinstalling, ensure that the body and filter element are dry.
Parts Information
Part Number
Description
15086429
Hose Asm-Evap Emis Cnstr Vent
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
L0260
Hose, EVAP Emission Canister Vent Valve Asm - Replace
0.4 hr
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
I checked it out at the dealer, wow, the d**n thing is worth $410 list and $328 for my price. I'm going to check it out tomorro and see if I can't figure out some way to use the existing setup with cleaning and better filtering location or something. It has lasted 5+ years and 220,000km now so, maybe I can get some more out of it with a little TLC.
Thanks again, and I'm sure I'll be picking your brain again, Roy.
    • When I bought my 14 GMC I turned it off with an handheld programmer. With my 16 Odyssey I left it on solely because I didn’t have much money in the vehicle. There’s a device to turn it off that’s a little more involved. The GMC at 72 MPH the deactivation was on very little the deference was 1/2 mile per gallon. The Odyssey is on over half the time at 72 mph.
    • Anyone ever thought about switching the interior door panels from the base model to the Denali style? I’ve seen that you basically have to cut, sand, mold, paint, the window switches together to get the look right. Is that the main reason people don’t bother doing the swap? Seems like the only method that is easy I guess, without having to mess around with wiring and stuff.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
