Need to replace Door Checks.. Help!!!
I have a 2001 Tahoe and the door checks are all rusted and squeek when I open the doors.. I can see metal on metal scraping..
The door check is that little metal blade that slides into the door at the hinge. It is what holds the door open. they are also sometimes called door Stays...
I heard that GM redesigned the door checks and made them out of some type of plastic...
What are the replacement part numbers for these new checks???
What's a door check?
A door check is that little metal blade that slides into the door at the hinge. It is what holds the door open. they are also called door Stays...
I had no idea what the hell they were called either.. somebody had to tell me too...lol
Anyone?? I know I am the only one that has a problem with these... :shakehead:
I have the exact same problem but never knew anything about them. I just sprayed some motorcycle chain wax on them and they haven't made any noise in months but I would like to replace them too. SO anyone with any info please help.
Anyone?? I know I am the only one that has a problem with these... :chevrolet:
Yep, I had greased em.. But they are so scraped up that they will never go smoothly again.. I just wanna replace em...
15173407 for the front and 15173409 is for the rear. I got them from GMpartsdirect.com searching the GM Alternate Catalog.
You Rock dude! so I order 2 each for the front and 2 each for the rear? There are no left and right variants?
Looks like just front and rear.
