Sierra 99-03 aftermarket foglamps
Been thinking about getting a set of aftermarket fog lamps for my 2000 Sierra.
I don't have factory fog lamps, so I don't have holes in the valence under the bumper (which is where I assume they went).
Just curious what anyone else has done in this situation. I really don't want to install a light bar or brush guard, and I don't want to block the center air hole in the valence or block the front tow hooks.
Not opposed to cutting the valence, although that would have to be done very carefully not to screw it up.
Can't think of any place to mount them other than maybe in the grille.
What have you guys done?
http://www.gmpartsdirect.com/results.cfm?s...number=12495928
Says it includes everything needed. Also says ECM will have to be programmed at dealer.. could run an hours labor. But that may only apply to the Tahoe/Burb, read the paragraph and see what you think.
I don't think it would matter if the lower air dam wasn't cut perfectly. The lights extend into it, I think, so you would have pretty good leeway for slip-ups. Wouldn't be worried about that at all.
Thanks. That's a nice solution, and not all that expensive. I like that it includes the switch and wiring.
The BCM flash is kind of a downer though.
There are some aftermarket kits that have similar lights in them. The consensus on the board seems to be that the stock GM fog lamps are pretty lame. Maybe I should just go with the aftermarket, and wire it in myself - that would save me the trip to the dealer.
I wonder if the valence has lines on the back to guide the cuts?
Look for an air dam with light pockets. Also get the Chrome top cap. I think the PIAA Blue Ion Fog Lights will fit this air dam.
I put Hella's in my stock airdam...but check this out, made by PIAA:
Unfortunately, I have a Sierra. Unless I remove the tow hooks, or cut holes, the only hole in the valence puts the fogs straddling the license plate in the center.
There is this on ebay, but with shipping its pushing $200, and I have to paint it.
Then I have to buy fog lamps on top of that, although I could use aftermarkets then.
This is probably a better option for around $75 (including shipping)
But again, if the factory fogs are as worthless as some maintain, it might be worth going with the more expensive option.
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
