Apology
firerage101
I made a post that was deleted do to a user agreement violation, for those who saw it i wish to make an apology if i offended someone and hope that if i did it can be forgotten. Hoep everyone is having a good day
No worries! Thank you for being such a nice guy about it. :flag:
