2002 Tahoe Wiper Problem
CYOKOM
I have an 02 Tahoe and the other day my wipers stoped working except if they are on full bore. I was hoping that maybe, I just blew a fuse, but I only found one fuse related to the front wiper which was good. Any help would be great.
Thnks so much.
It's either the wiper switch of the wiper module (board). Take your pick. If you want to do some extensive diagnosis, I can give you the steps.
Thanks for the fast reply. Any advice to diagnosis the problem more would be great.
I was thinking if the wiper switch isn't very expensive than maybe I would just go that route and see if it fixes the problem. Your thoughts?
Thanks again.
This is going to be difficult to follow. Start with step 2. After each step you'll see a reference to go to one of two steps. If the answer to the test is yes, you go the first number mentioned. If the answer is no, go to the second number mentioned.
Wipers Inoperative - One or More Modes
Test Description
The numbers below refer to the step numbers on the diagnostic table.
8. This step tests for continuity through the 24K ohms resistor in the windshield wiper/washer switch. The connector behind the instrument panel knee bolster is suitable for performing this step.
9. This step tests for continuity through the delay resistors in the windshield wiper/washer switch. The measured resistance will change in sequence from high to low as the delay speed is increased. The connector behind the instrument panel knee bolster is suitable for performing this step.
Step
Action
Value(s)
Yes
No
Schematic Reference: Wiper/Washer System Schematics
Did you review the Wiper/Washer System Description and Operation and perform the necessary inspections?
Go to Step 2
Go to Symptoms - Wiper/Washer Systems
2
Turn the ignition ON.
Operate the windshield wiper/washer switch through all the switch positions.
Does the windshield wiper/washer system operate normally?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
3
Do the windshield wipers operate in the high speed mode?
Go to Step 5
Go to Step 4
4
Disconnect the windshield wiper motor connector.
Connect a test lamp from the windshield wiper motor high speed circuit terminal to ground.
Operate the windshield wiper/washer switch to the high speed position.
Does the test lamp illuminate?
Go to Step 16
Go to Step 10
5
Connect a test lamp from the windshield wiper motor accessory voltage supply circuit terminal to ground.
Go to Step 6
Go to Step 11
6
Connect a test lamp from the windshield wiper switch signal 2 circuit terminal to ground.
Press the windshield washer switch.
Go to Step 7
Go to Step 12
7
Connect a test lamp from the windshield wiper switch signal 1 circuit terminal to ground.
Operate the windshield wiper/washer switch to the following positions:
- MIST
- LO
- HI
Does the test lamp illuminate in the listed switch positions?
Go to Step 8
Go to Step 13
8
Disconnect the windshield wiper/washer switch connector.
Measure the resistance through the windshield wiper switch from the signal 2 circuit terminal to the accessory voltage supply circuit terminal in the switch side connector.
- MIST
- INT
- LO
- HI
Is the resistance at or near the specified value in all the listed switch positions?
24K ohms
Go to Step 9
Go to Step 14
9
Measure the resistance through the windshield wiper/washer switch from the signal 1 circuit terminal to the accessory voltage supply circuit terminal in the switch side connector.
Operate the windshield wiper/washer switch through all of the delay positions.
Does the resistance remain within the specified values from high to low as the delay speed is increased?
38K - 690K ohms
Go to Step 16
Go to Step 14
10
Test the windshield wiper motor high speed circuit for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 18
Go to Step 14
11
Repair the windshield wiper motor accessory voltage supply circuit for an open or high resistance. Refer to Wiring Repairs in Wiring Systems.
Is the repair complete?
Go to Step 18
12
Test the windshield wiper switch signal 2 circuit for an open or short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 18
Go to Step 14
13
Test the windshield wiper switch signal 1 circuit for an open or short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 18
Go to Step 14
14
Inspect for poor connections at the windshield wiper/washer switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 18
Go to Step 15
15
Replace the windshield wiper/washer switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column.
Go to Step 18
16
Inspect for poor connections at the windshield wiper motor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 18
Go to Step 17
17
Replace the windshield wiper motor cover.
Go to Step 18
18
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
Here's the motor connector. You'll need to know a few of these to do the above tests.
Pin
Wire Color
Circuit No.
Function
A
BLK
550
Ground
B
YEL
143
Accessory Voltage
C
PPL
92
Windshield Wiper Motor High Speed
D
DK GRN
113
Windshield Wiper Switch On Signal
E
GRY
112
Windshield Wiper Switch Low/Pulse Signal
