when to change plugs ?
pastor scott.com
Ive always changed plugs in the past at 100,000 miles. now my 5.3 burb says 100,000. what should I do ?
Scott
also what about the debate about tranny flush or change. and when should I if all change the fluid
Scott
If you've changed them at 100k and the book say to do it at 100k, where's the conflict?
As for your fluid changes, following the recommendations in your owner information.
About the plugs, the mechanic I go to told me it isn't as much the mileage as the time the plugs have been in. He has wreckers that put on 100K in a couple years, so he can do them at 100K, but if it takes you 5-6 years to go 100K you may find you have some frozen plugs which is not a good thing.
    Fishboat
    Fishboat
  • Who's Online   4 Members, 0 Anonymous, 629 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
