suspension upgrade questions!!
:confused: Was wondering if it is possible to upgrade my 05 1500 z71 xcab long box to 2500 series suspension and will it void my warranty??? :cry:
Welcome to the site. Not to sound like an ***, but why? What do you haul? Are you just looking for height? Do you hae a donor truck lying around? I'd be worried about stopping that much weight with stock 1/2 ton brakes. I think the cost to benefit ratio would be steep. Just a guess, but pretty sure you could kiss your warrenty goodbye! If you pull it off let me know, I put 3/4 ton springs in the back of a 95 1/2 ton(sold since then) a while back, didn't stop as well as hoped. Just my thoughts. Good luck.
I would suggest helper springs or air-bags, if you're going for weight capacities.
Yes if you modified your truck that much you would void most all warranty. My suggestion would be wait till 3-36k is over than swap in a straight axle. Off road unlimited sells a kit for the spring hangers. Many different front diff combo's availible that would be way way stronger than a IFS ever will be. Better off road also. The put in a 14 bolt in the read with your choice of springs and off ya go.
    Bl5650
    Bl5650
  • Who's Online   5 Members, 0 Anonymous, 834 Guests (See full list)
