Lift Kits
Hi, im going to be getting a Silverado in a few months as a graduation present and I wanted to put a lift on it. I will do a little bit of mudding and thats probably it for that. But I was leaning towards a 6" suspension lift, I dont know if thats what I need though. I want a lift that wont require me to adjust any parts underneath, i want everything to stay the way it is. I also want to know what kind of risks i might be getting myself into, people tell me its constant maintenence on trucks w/ lift kits. I just wanna know everything I can possibly know on the subject.
I really dont know what is even necessary!
Thanks from a newbie!
AKA ~Nuthinfancy~
ANY vehicle that is run hard will need constant maintnance. That being said there are many different brands of 6" lifts out there. Of course the best one is the one you end up buying. I run a Pro comp but there are guys here that have skyjacker, rancho, fabtech, cognito, rcd, superlift, rough country and so on. check out these two sites gmfullsize and fullsizechevy and read there stickeys in the off road section There is a whole bunch of info that should answer any question you have.
you could also try Pavementsucks.com they have a plethora of knowledge about everything from soup to nuts....Lifts, tires Solid Axle Swaps, tranny and engine swaps, etc. The guys on there know just about all there is to know, so skip on down there if you need some info.
I have a 94 Z71 ext cab on a 6" RCD lift and a 3" body lift with 35x12.5R16 BFG Mud terrains. RCD, CST, and Cognito seem to put out really good products. Do not get a lift because the price is cheap, the quality of the parts and fitment outweigh a couple bucks in the long run. In terms of problems, Drive axles blow a pretty good amount of the time, so you will probably get good at changing them. Ball joints also go at a quicker rate, and you gotta take it easy if you dont upgrade your steering components. There are other problems that occur, but those seem to be the main ones, oh and the s**tty front axle actuators go initially until you upgrade them. PITA in my opinion. Hope this helps a little, definitely check out Pavementsucks.com and maybe Pirate4x4.com as well, but dont be surprised if you get flamed hard on Pirate, those dudes are all like master fabricators and seem to hate newbie questions.
rob :crackup::cool:
Well said. :crackup:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
