2001 2500HD 8.1 Ally Trans prob
8100 Power
Hey guys,
I was backing out of the local grocery store and i put my truck in reverse and was backing out, and all of a sudden the truck came out of reverse, so i tried to get it to go back in it, and it wouldn't, so i shut it off and still no luck, so i put it in drive to go back down the road, and the truck was stuck in 2nd gear, it would start from first, and it wouldn't go past 2, so when i got where i was going, i let the truck sit for about 3 hours...so i started and the ses light come on and it started to work like normal, so whats my problem..... :eek:
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 253 Guests (See full list)
