Want to install nav system on my 2005 Tahoe LS.
j.r1105
Can anyone tell me if I can install a navigation unit on a 2005 Chevy Tahoe Ls.
Since I don't have Y91 code on the glove box sticker I don't know if I can do it, my truck came with factory install head unit with cd and cassette player, stering whell controls and onstar.Can anyone tell me how to find out if I have any amp. In my truck already install or what can I do to install the nav unit I was thinking about part #15108421.
Do you have BOSE? If not, you don;t have an AMP. So you would be able to choose either TNR (Lux) or a NAV (no-Lux) but you woul dhave to get either one of the Amps (lux or non lux).
At least that is the general idea that I have gotten from all the reading.
So you are saying I need either lux or nonlux amp.? Question is what amp part number should I be looking for and Where can I find this amp. Besides the dealership any other place that sell this parts and maybe the wires to set it up.
Yea.  You are going to need one of the Amps either way.  It'll depend on what NAV system you want.
I would read this thread
http://www.gm-trucks.com/forums/index.php?...ic=28030&st=825
That is the end of the thread, but you can move around.  It started in 2004 so, I started in the newest and worked backwards looking for bit of info.  There is a TON in there that will help you.  Just read.
You wkow I have order nav screen part# 15108421 about a week ago I received today I was afraid was not to work but after tried and removed the old unit and install the nav unit in actually work the unit is install and working well I guess didn't need the amp. The only problem is the chime sound is very low with the old unit I can reset it but with this unit I didn't find any thing on the manual to restet the chime volume.
Anyway I have another question does 2003 and up chevy's come standard whit the vss wire already in the connector or I need to do somethig to get it to the nav unit. Thanks :confused:
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 686 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
