pilots should be like this dont ya think
3500in nc
D**n Straight! Now that's what I wanna hear whenever I get on a plane. The best offense, is a big, powerful, defense! Speak softly and carry a big-a$$ gun.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 1 Anonymous, 549 Guests (See full list)
