04 colorado front tires wear on inside
devo
Has anyone else had problems on colorado front tire ,inside tread gone.
I heard you could ref to ID# 1686447 or #04-03-07-004b, would correct the problem and replace tires. has anyone heard of this.
Which tires came with your truck? I have a Silverado, same year, and had the same problrm. I have the Bridgestone Duelers. Apparently these tires had some problems wearing unevenly from the factory. Alignment was fine and they still wore badly on the insides.
My Colorado came with Generals. I found a Bulletin back in July 22,2005 where
some 4wd models had problems with incorrect Z height trim setting. resulting in excessive front sum toe-out. No recall only a Bulletin . But to take back to dealer to fix problem and replace tires if needed.
http://www.alldata.com/tsb/General-Motors/...004B/40041.html
    250.3k
    Wasierra1500
    Wasierra1500
  • Who's Online   2 Members, 0 Anonymous, 594 Guests (See full list)
