Broken Mirror
I have a 1999 Silverado. I have the mirrors that you can manually fold in toward the truck, and they also have a little give towards the front in case something hits them. The other day I was backing up and my passenger side mirror caught some branches and it got flipped all the way forward(as if it were a hyper-extended joint). The cable is still attached and I can lift the mirror off the base a few inches and I'm unable to see any broken parts. Is there a way this will go back together with pressure, or am I better off finding a new/used mirror and replacing it? I'd appreciate any help. THANKS
P.S. I have it rigged right now with a black bungy cord wrapped the mirror and the base. It seems to work but doesn't look the best.
It is not likely broken. There is a post that the mirror pivots on. There is a spring that fits over the post and it is compressed and held in place by a friction ring. It can be fixed for $0.
Carefully remove mirror glass by adjusting it all the way in and reaching in with a screwdriver to release clips that go around the backing plate of the glass. Once removed, you will see the problem. It is easiest to completely remove the mirror assembly but I managed to fix it on vehicle. I used a socket to fit over the cap and a large clamp to squeeze the spring and retaining clip back on. Be careful if you have the wire going through the post as you can break it if not careful.
I have had to do this on both mirrors once each.
MSU............If you broke the detent tab by bending it backwards
its toast and your better of checking fleabay or your local Pep Boys.
They sell the complete power only mirror assembly for less than
$50 bucks. Its a "knockoff" made in china? but a LOT cheaper
than genuine GM.............
Check out this link for full pics and instructions on how to
attempt to repair/disassemble your mirror.............
http://www.fullsizechevy.com/forums/showthread.php?t=175712
...........geo
