Important
dhl5015
I would like to know if it is possible to replace just the bow tie on the front of the grille instead of having to replace the entire grille. And if so is there a website that shows how to do it. I am going to court tomorrow and would like to if possible replace just the bowite,spending 50 at most instead of replacing an entire grille spending 450.
Thanks
Thanks
I am pretty sure there is...try this...
-Remove the grill...it should snap right out of its clips
-Look at the back of the grill...there should be 2 small bolts with thin nuts on them, unscrewing these will remove the bowtie.
You can buy replacements online. My brother did this for his billet bowtie. I'm not sure on the silvy's, but check and see...the grill comes off with pop-in clips i think.
Just outta curiosity, what's going to court have to do with replacing the bowtie? Get a ticket as a result of an improper accessory? If so, didn't you change the bowtie yourself?
Just asked the question that I wondered when I read it too.
Well I was driving around with some friends and made the stupid mistake of throwing a snowball at someones truck thinking it was a friends :sigh: . The snowball was smaller than a baseball and hit his truck and he is saying that it craxked his grille. I think it was just a rock chip that he didnt realize until i hit the grille. So tomorrow I have to go to court to settle it all and he is asking for 463 for a whole new grille when just the bowtie is cracked. So if the judge beleives that the snowball cracked the grille then I will try to replace only the bowtie and save over 400.
12335700 is the part number (For '03-'06 Silverado Pickups) for the bowtie emblem itself.
If you take the cover off the top that has 6-7 push locks in, you can easily get to the 2 nuts that hold the bowtie in. Real easy to do.
He is not answering because they made him buy a whole new truck. :banghead:
Turns out that snowball also cracked the engine block and split the frame in two.
    Brendan C
    Brendan C
  • Who's Online   0 Members, 0 Anonymous, 1,071 Guests (See full list)
