Adding second battery to 99 Suburban
While digging under the hood I noticed that there is a second battery tray up front. There is also a long stretch of wire that runs by this tray. It appears that there is enough to cut it and hook it up to the new batteries terminal.
Anyone here added a second batter? Is there a place by the new tray that I should hook the negative to?
Thanks for the info, I appreciate it.
The setup that I have is different from the picture posted. I'm pretty sure that I already have the isolator installed.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
