Biggest tire that will work on 99 Burban
I have 16" wheels and was wondering what size tire I can get away with.  I'm at stock height right now and want to avoid any rubbing etc.
With a little crank of the front torsion bars, you can fit 33 x 12.50 R 16's
I guess I'm not exactly sure what the torsion bars do so I'm not so sure I want to do it :cheers: I have a lot to learn! :cheers:
Once the torsion bars are adjusted would I have any issues with rubbing? I'm looking to buy BF Goodrich All Terrain TA KO tires and I see that they make them in the 33 x 12.5 R16. I also see that they have a 32 x 11.5 R 16 that I could use if rubbing will be an issue.
I dont quite understand the sizing of the tires listed above. I currently have 265x75 16's on it now and understand how that sizing works.
265/75/r16 is equivalent to 32x10.5
285/75/r16 is equivalent to 33x11.2
33 x 12.5 R16 will work on your truck
Thanks for the info. I guess I looked at the website wrong. I guess BF Goodrich tire I was looking at is not offered in a 33x12.5 R16 (at least not at tirerack.com and discounttire.com). I will have to keep looking around.
this is the best website to go to they will beat any price out there. I use them for all of my upgrades
4wheelparts
BFGoodrich Radial Mud-Terrain T/A $204.99 each
Size 285x75-16 LT
Solid White Letters
Load Range D
