Lift kit
Anyone used this Rough Country Lift Kit?
I called and it contains:
(W) Front torsion bar adjuster keys, rear blocks with U-bolts.
Are these torsion bar adjuster keys similar to what I have been reading about in other threads that can be bought at the dealership?
If so, I was also thinking about getting the keys and using add-a-leaf in the rear.
I'm only looking for a 2" lift.
thanks
I wish I could have been happy with just 2 inches :thumbs: . Anyways, buy a set of the "ford key's" off of ebay for cheap and and get the "add a leaf" or 2" block for the rear. The "ford Keys" will replace the stock torsion bar "keys"; they are indexed slightly, and it basically cranks up the torsion bars. Just don't go over 2" in front.
You will then need to get the front realigned.
Good luck.
JC
Thanks. So are the Ford keys the same(or similar) to the aftermarket keys? On my 2000 Silverado I just cranked up the torsion bars to level the truck out and my 285s fit. So, can I crank up the torsion bars and then add the keys to get another 2"?
Also, what do you recommend? The add-a-leaf or the blocks? To me the add-a-leaf seems like it would be better.
  • 6 months later...
mine has torsion keys in the front and an adda leat in the back and it's absolutely perfect....bout 1.5 inch lift.
I'm 305/70 series maxxis mudders with not a problem in the world.
-Ronnie
one of the best kits is the RCD lift or Fabtech, i have the RCD lift and it is awsome, but trust me you get a 2 and you will be happpy for a little while, but then your gonna wanna uprgade, just get a 6 and put some step bars on
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 587 Guests (See full list)
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
