keitkeit Posted April 3, 2006 Posted April 3, 2006 Ok, so when I connect my radio it will not come on. None of my gauges or inside lights work. Now when I connect the yellow and red wires all together(ACC and Battery+) It will come on and my gauges will work. This is the only way though. Is a fuse blow somewhere? If so where? I'm so confused. I've been messing with this forever. Note: It worked right before and I switched head units and I think maybe I touched something that i shouldn't Have.
bobcat5544 Posted April 3, 2006 Posted April 3, 2006 CHECK THE 15 AMP FUSE LOCATED UNDER THE HOOD IN THE FUSE BLOCK IT SHOULD BE LABELED RADIO IF NOT BLOWN THEN CHECK THE 10 AMP FUSE ON THE LEFT SIDE OG DASH IT SHOULD BE LABELED RDO 1 IT SHOULD BE THE ONE UNDER THE HOOD, BUT CHECK BOTH YOU SHOULD FIND ONE OR THE OTHER
keitkeit Posted April 5, 2006 Author Posted April 5, 2006 CHECK THE 15 AMP FUSE LOCATED UNDER THE HOOD IN THE FUSE BLOCK IT SHOULD BE LABELED RADIO IF NOT BLOWN THEN CHECK THE 10 AMP FUSE ON THE LEFT SIDE OG DASH IT SHOULD BE LABELED RDO 1 IT SHOULD BE THE ONE UNDER THE HOOD, BUT CHECK BOTH YOU SHOULD FIND ONE OR THE OTHER <{POST_SNAPBACK}> Thanks. It was the one under the hood. Everything works right except my interior lights now. They will only come on if I set the knob all the way up so the interior dome light comes on. Any idea on this one?
bobcat5544 Posted April 5, 2006 Posted April 5, 2006 Hit the "dome override" button once? <{POST_SNAPBACK}> sorry just had to
asilverblazer Posted April 5, 2006 Posted April 5, 2006 I fried my dimmer switch in similar fashion, if the dome overide isn't it you might need a new dimmer.
keitkeit Posted April 6, 2006 Author Posted April 6, 2006 Not the dome override. Could be the switch. the lights only come on with the switch all the way up as i would be turning on the dome.
