2ft. cb antenna in stake hole
Hey guys...I just ordered the CB that i am going to mount in my dash (see other post) and i also ordered a 2ft Wilson fiberglass antenna with a stake hole mount. However, i just read that you have to have atleast a 3ft antenna for that mounting position because you have to have at least 40% of the antenna above the roof line. has anyone tried this set up with the 2ft...does it work ok? Can anyone confirm this issue because if it is true I need to order a 3ft instead.
Thanks guys
The 2'ft antenna will work there. I had a 2' antenna on my truck while working at my last job because I would park in the parking garage. It would be better to have a a longer antenna but you should still be able to get out a few miles with that set up.
Thanks for that reassurance...I will stick with the 2ft. and maybe pickup a 4ft. and just throw that one on for long road trips...
Does anyone know if i need to recalibrate swr if i switch antenna's?
Also any other opnions on this set up would be great!
It may work but you probably won't transmit very far. I have dual 4ft mounted to my toolbox with a Galaxy 959. I get 1.5 SWR on 1 & 40 with 1.3 in the center 20. Make sure the antenna is grounded properly and you check the SWR. The antennas are not plug and play, they still require adjustment.
Anytime you change antennas you have to check SWR.
CB's basically work by "Line Of Sight", so the longer the antenna, the further the reception/transmittion, but not necessarily better.
And, like MR. Smith said, it will need adjusted when changed to work to the best of its ability.
Thanks for the help guys....i am assuming that when you say to make sure i have a good ground...you mean from the CB to the chassis...or are you reffering to the antenna needing a good ground...if you are reffering to grounding the antenna...I have never had to do that so any help would be great.
I think i will try the 2ft.er and see hwo it goes....As for tuning it i have an adjustable tip antenna...how do I calibrate that with my radio...do i need an SWR meter...if so where do i get one and how much $... or where can i take my truck to have it looked at ...Maryland
Thanks guys!
Thanks guys!
The ground is for the antenna mount unless it is a No ground plane antenna. That sounds like a Firestick antenna. You can pick up a decent SWR meter for less than 25 bucks online unless you can buy it from the place you picked up your radio gear.
I am stopping by radio shack tonight to pick a swr meter up for $30...as for the antenna...it is almsot the exact same as the firestik...it is a 2' fiberglass that is screwed into the mount in the stake hole...
Now you mention grounding this antenna...how do i go about doint this. As of right now i have a stake hole mount kit from firestik and the 2' fiberglass antenna, i also have the coax running to my Cb... HOW do i ground the antenna...do i really need to ground the antenna and the CB Radio itself?
Run a ground strap from the antenna (or one of the bolts on the mount) down to the frame and ground it. This is the best way to do it. There is also a "ground plane" with cb's that needs to be addressed with your setup. The best ground plane is the roof of a vehicle (why you need 40-60%) of the antenna above the roof and preferably in the center, unless running dual whips). With a 2' whip your distance transmission will be seriously limited (1-1.5 miles in ideal conditions). Personally I would go for a 4' whip unless clearance is an issue.
A heads up for toolbox mounts; if you get your bed sprayed with a liner and don't have the toolbox grounded to the frame, you will need to. The Line-x interferes with the ground between the toolbox and the bed and really screws your SWR. I figured this out after about 2 hours of adjusting, readjusting and trying to figure out why my SWR went out of adjustment, quick ground strap to the frame and she was back to perfect! :banghead:
A heads up for toolbox mounts; if you get your bed sprayed with a liner and don't have the toolbox grounded to the frame, you will need to. The Line-x interferes with the ground between the toolbox and the bed and really screws your SWR. I figured this out after about 2 hours of adjusting, readjusting and trying to figure out why my SWR went out of adjustment, quick ground strap to the frame and she was back to perfect! :chevy:
Ok...i got the run the strap from one of the bolts to the frame...but how in the world do you attach it to the dirtygunk covered frame?
AND...You say only 1.5mi....can anyone else attest to this info? I cannot believe that i would only get that far out even with only 5-6" of the antenna above the roof...I have heard guys that have a 3ft. and can push 7-9mi
Clean a spot and attach it. Your mounting location, radio, antenna will all factor into transmission power. Remember that you are limited to 5 watts so any imperfections in any of the above will lower your transmission output.
This site is very good. Read it and it will help you understand a little more.
Tech Docs
Keep that ground wire as short as possible and the largest gauge of wire possible. Mine is less than 18" and 10 gauge wire. If you make it too long you can create a ground loop. I am no expert but I rely on an avionics tech at the place I work.
I would have a hard time believing 7-9 miles with a 3' whip. With A 108" stainless whip its quite possible. Lots of factors come into play, terrain, wiring, grounding, vehicle, other peoples equipment that are beyond control and can affect transmission. I would be surprised given average conditions that you will get anymore than line of sight with your setup. Mines pretty good (not ideal, but good)(see sig) and the furthest that I have been able to verify is 4 miles (I think I can get out about 15 but have never proven it) and my radio has been peaked and tuned over the stock wattage. Check out www.cbradiofourm.com. Gijoescb.com or something like that is a good place to buy radios and have them tuned. Thats where i got mine and I am very happy with it.
Watch the ground loop, keep your cables as short as possible. Also buy a custom made harness for the coax cable for your application and don't shorten it! A little reading and reaserch on the web will go a long way in deciding what to buy and how to hook it up for the best results. It took me 4 or 5 setups to figure this out!
Thanks for the help guys...i will try these ideas and see how i come out...i will definatly post the final results
    • Oh yes, someone is going to be certainly hitting up GM service/ support for a 20 year old truck.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
