RPO Codes
Hey Guys...so after taken some time looking over my VIN codes and the decoder on theis website I had a few questions.
1) I have a 94'. Do the VIN codes change from year to year? Ex - Does M30 = 4L60-E for every year?
2) Because mine is a few years older than this website lists, where might I go to find the older codes? Maybe we should start a list? I'd be happy to submit what I have.
Thanks guys.
Mike,
I've been in the GM parts business for over 16 years and yes,some RPO codes do change over the years (M30 hasn't-Its still means 4L60-E)
But some do...Example:"Z06"...We might think of that as a Corvette option,but from 1976 to 1988 RPO code Z06 meant "Luxury Interior"
Another one is "L33" Today its for the 5.3-5300-"H.O." V8 engine for the 1500 trucks,But from 1976 to 1979 it was the code for the 425 c.i.d. V8 engine for the Cadillacs.
So to answer your question,Some codes change meaning,some don't.
Mike,
Thanks Dale,
How might I properly decode that sticker? I would emagine that not much changes from 94 to 98, so I'm confidant the ones I decided are accurate, but I have a lot of blanks.
Thanks again
List the blanks you have and I'll try to decode them for you.
Some RPO codes are blank however,They are used for plant build or ordering purposes only and do not have a description.
ah thanks, thats mighty kind of you.
C5G
FWI
MXO
R7C
R7R
RBT
SLM
SVA
TR9
UX1
U16
U66
VX5
XBB
ZQ2
ZQ3
15D
15Z
6WK
7WK
Thanks again!
C5G
FWI
MXO
R7C
R7R
RBT
SLM
SVA
TR9
UX1
U16
U66
VX5
XBB
ZQ2
ZQ3
15D
15Z
6WK
7WK
Thanks again!
Heres the ones I got:
C5G=5600 LB. GVWR
FWI=ASM.PLANT CODE,FORT WAYNE,IN.,GM TRUCK & BUS PLANT
MXO=MERCHANDISING OPTION,TRANSMISSION,AUTOMATIC OVERDRIVE
SLM=STOCK ORDER
SVA=CUP HOLDER
TR9=LAMP GROUP,COURTESY
UX1=RADIO,AM/FM STEREO,CASSETTE,EQUALIZER,ETR,W/CLOCK
U16=TACHOMETER,ENGINE
U66=SPEAKER SYSTEM,4,DUAL FRONT DASH MOUNTED,EXTENDED RANGE REAR QUARTER MOUNTED
VXS=VEHICLE COMPLETE (YOU HAD THIS AS "VX5" BUT I THINK ITS "VXS")
X88=MODEL,CHEVROLET (YOU HAD THIS AS "XBB" BUT I THINK ITS "X88")
ZQ2=DRIVER CONVENIENCE PACKAGE (TILT WHEEL/DELAY WIPERS)
ZQ3=DRIVER CONVENIENCE PACKAGE II (POWER WINDOWS/POWER LOCKS)
15D=TRIM COMBINATION,CLOTH,MEDIUM SLATE GRAY
6WK=COMPONENT FRT. LH COMPUTER SELECTED SUSPENSION
7WK=COMPONENT FRT. RH COMPUTER SELECTED SUSPENSION
I couldn't come up with anything for the "R" codes,Most times the "R" codes are sales control items.
Also check "15Z" for it possibly being "152" and I think "RBT" should be "R8T"
If "152" is it that is for:TRIM COMINATION,MEDIUM SLATE GRAY,LEATHER
And on "R8T" it is for:SALES CONTROL ITEM 69 PROCESSING OPTION
I had a '94 K1500 also and I just ran my VIN for the codes and I also had the "R8T" and "R7R" codes on my truck.
Rich. :chevy:
C5G
FWI
MXO
R7C
R7R
RBT
SLM
SVA
TR9
UX1
U16
U66
VX5
XBB
ZQ2
ZQ3
15D
15Z
6WK
7WK
Thanks again!
C5G=5600 LB. GVWR
SLM=STOCK ORDER
SVA=CUP HOLDER
Rich. :chevy:
Thanks a million. It's def. not 152, although I wish haha. No leather, just cloth bench. Its a RCSB. Thanks a ton man! :D
    250.3k
    user087
    user087
  • Who's Online   5 Members, 0 Anonymous, 987 Guests (See full list)
    • Thanks @newdude, guess I'll keep looking.  Test driving so many trucks that have obvious things broken, I'm thinking "if they couldn't even be bothered to fix the power seat," what else is broken".   Just drove a 2021 where the power seat motor was grinding/binding and wouldn't do anything but make a terrible sound.   An owner that puts dents on the bumper, doesn't fix a seat motor, and had spotty service intervals (along with missing major services) doesn't give me the best of confidence.   Amazed at the number of people that will finance a $60k+ truck, run it into the ground, then trade with a loan balance (every single one had "loan/lien reported" on the CARFAX at the last year of registration).
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
