2500 HD Hood
I have a Nice hood off my 2001 Silverado 2500HD It's Charcoal , Grey Color, I have no need for it I put on a cowl induction hood, and hate to see it go to waste
I would like $100 for it.. It's located in Battle Creek, Michigan..
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
