Installing XM Antenna
03Silvy
:banghead: I have an XM Roady 2 I wanna throw in my 03 Silverado because it did not come through with the XM. Where is the best stop to run the wire through to the outside??? How do I do that? :)
I ran mine through the third brake light. Remove the screws holding it to the cab, run the wire through the hole, then along the headliner and down along the door frame trim, then up under the dash on the passenger side. This is on a 98 Chevy, should be similar on the newer body style.
I my Roady mounted on the left corner of the dash on top. The wire then runs down the door to the floor where it goes under the door sill. Once at the back of the cab it comes out of the sill and then out a rubber vent. Once outside the cab run it up along the edge of the windown to the top where it is mounted just inside the channel in the roof. I have had no problems with the wire coming out of any of the channels.
Have a good day.
Bill
Third brake light on my 97 as well.
    overspeed
    overspeed
  • Who's Online   3 Members, 0 Anonymous, 1,102 Guests (See full list)
