Idle rough
Hey,
Just today our '96 Suburban with 5.7l started to idle rough and the heater recirc and A/C lights are flickering off and on. Any ideas? Thanks............Zorrro :nono:
Are you sure that these two problems happened at the exact same time? Is the SES light on? Also, does it miss under a load? Just trying to narrow it down. :bs:
Yes, they happend at the same time. Last week I noticed The recirc lite would flicker at idle. Now the idle is loping and the lights are flickering at idle. No Service engine soon or other warnings are not present. Still looking for an answer. runs great under load gets 15-16 mpg. Thanks.....................Zorrro
