Raised hood on new Silverado
This is strickly a curiosity question....
We just got a new 2006 Silverado 2500HD at work. What I have noticed is the design of the hood on the truck is raised up in the middle (a lot more than like an 03 Silverado 1500). Looking at it I don't really see a particular engineering reason that the hood is raised, engine does not sit up or anything.
So is it just a cosmetic thing? Or is there more of a reason in the design.?
Well anyhow I think it looks pretty cool!! :nono:
What model(s) (&/or year) trucks have this?
Yeah, the 01-02 Silverado 2500 HD's and 3500's had the "Power Dome" hood. I thought is was a mistake when they changed the front clip and eliminated it. Appearantly the design team at Cherolet did too. In my opinion it is a retro idea. If you look at the 69-72 Chevy/GMC hoods they have a "Power Dome" look to them. Every GM truck buff in the world knows that 67-72 was the best body style on a pickup ever, brand for brand, period.
There's no practical reason for the Power Dome hood. It's on there for looks. And if you ask me, it looks pretty cool.
2006 is the first year where the non-HD trucks got the PowerDome hood.
Guest chevydeerhunter
I don't know, the Tri-Five's, particularly the '57 was pretty awesome.
.... 67-72 was the best body style on a pickup ever, brand for brand, period.
You've obviously never enjoyed the subtle beauty that is the '61 Studebaker.
:nono:
Somebody told me that the power dome hood was used on the 2500and 3500 series trucks because the Duramax diesel needed extra clearance under the hood. So apparently it is functional on diesel pickups, and cosmetic on everything else.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
