lights off switch
on my new sierra when i turn the lights switch to off it doesn't click it just returns to the auto position. My manual calls for 4 settings.
lights
day lamps
auto
off
do i have to take it back to a dealership to have fixed? if so, this qc check really was missed
I think it still shuts the lights off until you manually turn them on, or you shut off and restart your truck.
I have that set up
I leave it at auto...but if i want to turn my lights off i just turn it counter clockwise to the off position but, yes it returns to auto, but my lights go off. THey will stay off untill you restart your truck
lights
day lamps
auto
off
It is supposed to. It is just a momentary switch that latches/unlatches a relay. You will be able to see the little LED change color. It is located next to the auto setting. Also, if the photo cell on the dash senses a dark setting and turns the lights on, and you manually switch them off, the cluster lights will still illuminate, but the head and park lamps will shut off. Make sense?
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
