5.3L V8 & 3.73's
I've been driving my 2006 GMC Sierra for about 2000 miles. It has the 5.3L V8, 3.73 gear ratio, crew cab, & 17" wheels. I had a 2003 Sierra with the same engine,rear ratio, in an xtra cab. The 2006 is not fully broke in, but it doesn't have the engine response of my 2003. The '03, with just suttle foot input will just about haze the tires right from the get-go. The '06 isn't the same. Lots more foot input to get the truck moving. What's causing this? I'm always curious what changes are made from year to year, and hope I'm not disappointed with them. I love this truck in every other way, but started questioning things like, are the gears in the truck different from the window sticker?? Will the combination really change once the engine is broke in?? Can anyone share some input here?
Thanx; "The Cellardweller"
Howdy,
I have an 04 with the same engine and gears. I am running 285X75X16 tires. It was the same powerless feeling set up as yours. I ordered a tune from W4Me and it is a new truck. It will haze the tires now and the shifts are much better. I think that they are adding more torque management each year which makes them seem powerless. Good luck!!!!
Throtle by wire this is in the 05+ trucks suposed to help mileage, but i like the non spining at least i just get up and just GO!! Thats when i take it in slow mashing the gas pedal will leave me 2 tire marks ;)
You need to get your PCM tuned to get rid of the torque management that is robbing you of your off the line torque. Mine will light up the tires from the line now, wouldn't bark them when the pcm was stock (and with smaller tires).
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
