Sway Bar End Link
Heard a rattling from my front end, sway bar end link was broken. I bought a replacement kit and can't get it mounted. I can't get the bolt to line up because the top of it hits the upper A-arm. Is there a secret to getting it installed?
You have to loosen both sides, ends and possibly the two brackets that hold the bar to the frame. Once all the bolts are loose just get them finger tight and in the proper place and then tighten them up.
I bought another end link kit for the driver's side. I removed the old link, was able to put both of the new ones in, but I can't start the nut from the bottom. The new rubber bushings are thick enough that by the time I get all four in place with washers and the steel sleeve, there isn't any thread sticking out of the bottom for the nut. How do I go about compressing the link down enough to start threading the nut?
The threaded end of the bolt should point upwards and you put the bolt through the LCA and put the nut on the top. The reason for this is you do not want the bolt sticking downward as it can be torn off if you hit something. When the bolt is pointing upward there is nothing hanging below the LCA to get damaged. Once you place the bolt upward place a block or something under the LCA to hold it in place and then try and compress the bar downward so there is enough thread to start the nut. You may have to remove the front wheels.
The reason I ran it from the top down is because that is the way the original links were mounted. Based on the amount of visible thread on the original, I cannot run it the way you suggest because the bolt will come into contact with the upper control arm. I did place the new bolt next to the original bolt for comparison and the new is just a couple threads longer.
The threaded end is attaced to the top of the LCA. The LCA is thick enough that the threads never extend past the bottom edge. There is a rubber plug that closes up the access hole on the bottom side of the LCA.
    • If all oil manufacturers had to meet a higher standard for not just the initial filtering of the oil but that they had to improve on their formulation so that the oil cleaned the engine such as the Valvoline R&P or the new Mobil product ( assuming it works similar of course ), and the oil was changed on an interval based on good UOA data, there shouldn't be any gremlins running around like miniture rats on top of your heads to be washed down into the oil pan below 😁
    • Worst factory HD wheels GM makes
    • A while back on another thread there were comments and thoughts on air filters and I know that can tend to be a bit of a hot topic because of outfits that have a vested interest in selling aftermarket air boxes fitted with the gauze type of oiled elements touting the lower air restriction. However and unfortunately I don't know where I have seen the test results in the past about the amount of dirt through a test procedure that these style of filters do pass more dirt through than a properly designed ( not some cheap Chinese knock off ) paper/synesthetic media filter can do. Lake Speed had a conversation on that topic with one of the employees at Donaldson and there seemed to be a consensus of these oiled filters falling short in the absolute percentage of dirt holdback.    Which all ties back into how good the air filter is on the engine at keeping dirt out as that is going to reflect as a contaminant introduced into the oil as well as cylinder wear even if some of that dirt does find its way out of the exhaust rather then the crank case. Put another way that one can throw the kitchen sink at filtering the oil and using a bypass system which I fully expect will do nothing but good for the oils contamination but if the air filter system isn't doing its job then its preventing the engine from reaching the best wear/lasting case scenario instead.    Now perhaps this topic is or isn't for this particular thread but Grumpy Bear or anyone else for that matter, do you have access to some scientific trust worthy testing on engine air filter types to get some proper comparison data to post up.
    • WOW, something we agreed on. I only bought at sticker twice. A 94 impala ss and an Acura intagra type r. Made money on the first. Still have the second.
    • I prefer new, but not without a deal. Historically I've bought severely aged new inventory, leftover model year, unpopular configuration kind of stuff that sits around on dealer lots until they just want it gone. $10k off MSRP kind of stuff on a mid-priced truck. That really, really helps knock down that first year depreciation. It also requires being somewhat flexible on colors and options. I wouldn't buy a 4 cylinder if I was looking for an 8 cylinder, but if I got blue paint instead of black, or a great deal was lacking a minor option, I'm willing to overlook those things for savings.   Used <> used. Condition and history are everything. If I'm buying used I'm looking for cream of the crop. The truck from the guy who religiously pampers it, and then decides a year later he wants newer and nicer. NOT the ex-rental vehicle, or the crew cab traded in by the family with 7 kids who like to throw food, and the oil only got changed when there was time long after the oil life monitor started alerting.
