Z71 burb owners have a question
on your frt end with the driver side wheel turned all the way to the R.
You will see a bump stop. It sits between the frame and the axel.
I need to know
1) what color is this rubber stop
2) how tall is the bumpstop itself (measure in inches)
3) would love to see a PICTURE
4) does your suspention rest on it.
need to compare the difference between the Z71 and standard Burb hight bump stops.
GM shows to diff part numbers
Scott
