Torsion Bar Question
I am new to the trcuk scene, so please pardon my ignorance.
I just want to confirm I am reading everything correctly. Does the 06 2wd Sierra have torsion bars? From what I have been reading, it seems like it doesn't.
I would like to level my truck, but I do not want to lower the rear. From alot of the pictures I have seen, it appears to me that the fender well is smaller in the rear thant the front; therefore, it LOOKS like the rear is actually lower..even though it may be level. Is this true?
I would like to raise the front using this:
http://www.jpcustoms.com/store/customer/pr...&cat=816&page=1
Could someone please post a picture of leveled 2wd trucks, both lowered rear and lifted fronts?
Thank You
i can't answere your question but there is information on here that my help.but mainly i just wanted to say some torsion bar keys sell for about 15.00 dollars a piece so do your homework. a search on "torsion bars" might be a good start good luck.
i assume that you discovered no torsion bars? i've never come across torsion bars on 2wd model pickups. not to say that they don't exist, but i am yet to come across a 4x4 without them.
well, instead of researching, I immediately came here for the answer.
1) I should have just looked at my truck, or
2) Gone to GMC.com.  http://www.gmc.com/sierra/specsEngine.jsp?vehicle=1500
thanks.  I'm still learning, please bare with me.
I'm glad you provided that link that shows that the 1/2 ton 2wd pickup trucks do indeed have coil springs up front,because a few guys on here were debating weather or not they did.
Now the 1500HD,2500,2500HD and 3500 2wd pickups do have torsion bar front suspension,Along with the 1/2 ton 2wd SUV's (Tahoe/Suburban/Yukon)
Only the 1/2 ton 2wd pickups have coil springs up front.
  • 1 month later...
I love how whenever i post those pics a thread will just die because of course a picture is better than 1000 posts
Here are some pics of my 2006 2WD Extended Cab Short Box WITH Torsion Bars
Going back to the original question. Your 2006 2 wheel drive crew cab has coil springs.
The 2006 extended cab 2 wheel drive WITH THE SHORT BED has torsion bars. Who knows why.
NO GMC/Silverado 2 wheel drive between 1999 and 2005 has torsion bars.
The 2007 will have coil overs.
Have a great day,
Don :gmc:
  • 3 weeks later...
Have a great day,
Don :ughdance:
aren't the VHO's the only 1/2 ton, 2wd trucks with t-bars.
prolly. i think it's a GVWR thing most V-max are at or above the 1500hd. i wouldn't be supprised if they weren't 1500hds simply rebadged and the ho6.0 stuffed in.
I came into the same problem with my 2000 2wd and i got a $430 3in spindle lift kit off ebay and put it on myself. Its preety darn level with the 2in blocks that came with, now if I could only find a place where alignments are cheap. Also look at DayStar's 2in coil spring spacers if you want a cheap alternative.
  • 4 weeks later...
not all 2wd 1/2 have coils. best to check yourself before ordering parts. no matter what the GM site says.
I am new to this site and saw your truck and was hoping you could tell me how you raised the front to level it. I have a 06 Chevy Crew Cab and would like to raise the front as you did.
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 209 Guests (See full list)
