How do you remove Steering Wheel
nit78
The air bag module is removed by using a punch through the small holes on each side of the steering wheel. You have to feel around and take your time. Bad setup in my opinion. To get the wheel off you will need a puller and adapters with hooks on the ends. To be honest it might be easier to have it done at a dealer.
  • 1 year later...
Those directions are great does anyone know that can add to them the replacement of the clockspring or coil. That is what is wrong with mine. Is is somthing that can be done. Any info would be great.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
