2005 Chevy Suburban
I have a 2005 Suburban. Is there a way to disable the automatic door locking feature when you shift into gear. I went through the D.I.C. and the only options there are to lock the doors on shifting into gear or locking the doors when you reach 8 mph. I'd like to diable this so the doors do not lock period.
Me too. Can't be done.
Be sure to register a complaint with your dealer, though. If enough of us complain maybe they'll fix the problem.
Stick a fork in there. :seeya:
While this particular "feature" doesn't bother me, I can see how it's quite non-useful to others...This is a HUGE complaint for some people. Like ^^ he said...Make sure you file a complaint with the dealer (not much they can really do) and/or GM directly.
Couldn't you just re-wire it so the motor that runs the lock has power only when the button on the passenger and drivers doors are pushed? I don't see why the locks HAVE to be controlled by the computer......
rewireing might disable the key fob???
having the auto locks is great for me - my 3 year old has discovered the door handles and likes to open them. True, the child locks can be activated, but then I get stuck in the back too.
i'd like to make a rewiring job to disable the auto lock and no worries about the key fob, i don't have one :D `
could anybody help here :) ``
With the one wire system that the 03 and up trucks use, I dont think there is anyway to disable it. From what I understand, the BCM send a certain voltage to lock the door and another voltage to un-lock the door.
Maybe I am wrong, that is how it was explained to me.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
