tahoe suspension knock
I've got an '03 tahoe with 46,000 miles and I'm hearing a knock in the front suspension. You can hear the knock while turning, and you can feel it in the wheel pretty good as well. It does not knock while driving straight. What could this be? I don't know much about independent suspensions, I'm a jeep guy and this is my dad's truck so If someone could help me out it would be great!
Sounds like a UV joint. I'm assuming that the Tahoe is 4x4.
Sounds like intermediate steering shaft to me. Feel it in the wheel when turning going reasonably slow? If the cause, you need to lube it or replace it.
i was looking under her this morning, and it looks like the half shaft or whatevr you call it that comes out of the differential. I could actually twist the whole thing side to side a bit....
has anyone had this problem? If so does it need repacing or is there a way to tighten it down?
You are looking an the CV joint. There should be some play in those. In fact, unless the boot is torn, they wear really well. I've got 171K on both mine and the are still good. If you have a torn boot allowing water and dirt into them, they will wear out in no time. I'm not sure what the spec is on play but if the noise repeats faster as you speed up, it could be the CV. If the noise of "feel" in the steering wheel seems more times to bumps in the road, it is likely the intermediate steering shaft. This shaft is between the steering gear (below the battery) and the firewall.
ahhh i checked out that shaft, thats definately the problem. Now the question is, what would it take to fix that? It has a decent amount of play..
HERE is a great write up on lubing the intermediate steering shaft.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 634 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
