heel & toe tire wear on rear tires on 04 yukon xl
sixpackd
Hey guys
I have a bone stock 04 yukon xl with 17" rims and firestone tires.
I have 27k miles on the truck, and I have never rotated my tires.
across the tread, I have no issues, the wear seems pretty normal on the front and rear tires, ie no excessive wear on the inside or outside of the tread.
however on the rears, and only the rears, I have excessive heel-toe wear going on, to the point that just by looking at the tire you can tell the excessiveness, probably about 1/16 of an inch.
any ideas whats going on? the tire guy said it was the shocks, but the dealer says the shocks are just fine.
thx for any insight!.
Davis
I would rotate the tires. That way you get the best wear on them. I'm guessing you rear tires are feathering? If you rub your hand accross it you'll feel it. As for toe, you can't adjust it in the rear. The only thing I can think of is if you have the auto ride shoucks in back. Yes those could be a problem or some other part like a bushing. But I go with rotating the tires on a regular basis.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
